Tue Dec 19 2017
reconfigue slide clamp
how do you turn off the slide clamp
   RE: Infusion Pump Report Post
Tue Dec 19 2017Reply from MedWrenchMia
MedWrenchMia
MedWrenchMia
SOMA Technology would love to help! You can call their tech support at (860) 578-1041 with any questions.
Tue Dec 19 2017Reply from Hassan Serhan
You can go to the configuration mode and disable the slide clamp.
Thank you
Hassan
hassan@infusionpumprepair.com
Wed Dec 20 2017Reply from rcderek22
Enter congifuration mode by holding the black panel lock button on back + Stop while powering on pump,  then turn insert clamp to off.
Without the slide clamp, the safety stop will always stay engaged. There are two ways around this. Baxter makes a slide clamp blank that stays in the pocket, I've also had luck pushing a small screwdriver deep into the slide clamp pocket until it clicks. Either of these methods will make the safety clamp behave as if theres a slide clamp in place.
Hope this helps!
-Derek
Derek Snyder, CBET
