Wed Jan 03 2018
Ease of clock setting
What does the ease of clock setting actually do vs resetting the date/time manually? The operator's manual does not explain this setting. Thank y ou
Wed Jan 03 2018Reply from MedWrenchManager
Thu Jan 04 2018Reply from S. Rooks
Hello Jremily,
The ease of clock setting, when enabled, simply creates a screen that allows any user to set the time/date without the use of a password and gaining access the setup menu. (If enabled, this time and date screen will be seen when you press the [setup] key one time)
Steve Rooks, BMET
Southeastern Biomedical
1-828-396-6010
Biomedical Equipment Technician with Southeastern Biomedical 1-888-310-7322
