When I turn it on the screen says check system then the screen goes black and stays that way
Fri Jan 05 2018
Boot problems
Fri Aug 17 2018Reply from Carlos De Sousa
Hi. Could you let me know what was the resolution for this problem? I am having the same issue with one of my units.
Thank you!
Fri Aug 17 2018Reply from InsightMike
I’ve had this problem a few times with different machines. What I’ve done is this. When you power it on and the screen displays “ Check system” immediately power it of and then on again. Usually it takes a few tries. Just look for the “ System Booting...” display then let it complete the boot process. Niece you run a cycle or two you should not have this problem anymore. Hope this helps.
