The power supply do not function in battery mode, i've checked the battery voltage, they're 13 volts each. I also checked some components, diodes, fuses, diode bridge, they're all ok. I need help because this equipament is very important for intensive care unit of the hospital I work.
Thu Jan 11 2018
Power Supply do not function in battery mode.
Mon Mar 25 2024Reply from samasrar
My Drager Evita Xl ventilator battery is not getting charging voltage, all components are fine. Could you please tell me what you did to fix it?
