force fx
Have you checked in the documents and manual that is to the left with the with a picture? You can download the manuals and the manuals have the maufacures info so you can call tech support for answers.
Matt D.
Then try posting
"Is there a Biomed tech in my town _______________ I need servicing on a ValleyLabs FX, my email is _____________. Please contact me.
Matt D.
You can also request service on this equipment's page under "request a quote" and just specify that you need service. Thank you.
Best regards,
The MedWrench Team
Deer sir pls infrom me Valleylab force fx not support re-usable neutral plate.what can i do
You could use reusable (rubber) neutral electrodes on Force FX, but not with standard Valleylab cable with central pin. You should use cable without central pin Like Bowa 385-050 and neutral electrode 242-003.
Regards
