Sun Jan 14 2018
flow cell adjust
how do you adjust the flow cell for the differantials in a Cell Dyn 3200
   RE: Hematology Analyzer Report Post
Tue Jan 16 2018Reply from MedWrenchManager
MedWrenchManager
MYCO may be able to help with this question.
Tue Jan 16 2018Reply from Wytec Lda
Wytec Lda
you will require a service manual and some special tools for this assignment ,do you have these things ?
PRangel
Tue Jan 16 2018Reply from LabDr
yes i have the service manual and the latex particles. i thought i had it alighned good, the CV's are where they need to be. controls pass. but the patient samples are all running a little high on the Baso. i did replace the laser. could that be the difereance from a week laser to a strong laser. Thank you.
Wytec Lda
The Baso can not be higher regardless of having changed the laser tube .
make a fresh latex ( latron ) and fine tune the CV's to close o perfect
Did you change the laser and laser Power supply unit ? , some times it is better to change the power supply as well because a new tube could wear out the older laser power supply .
With good alighment
good CV´s
I feel that you are nearly there .
Are you using fresh blood samples for patient samples , from how many hours ago ? Are the baso results high on all the patient samples ? If possible draw blood and run a fresh whole blood sample .
baso raise as whole blood in the tube gets older .
PRangel
i would lik to send you pictures of the CV's i got, patient sample, and controls. to look at the histogram and tell me what you think. i could email or text them. i dont think there is a way to do it on this site.
MedWrenchManager
@labDr-- there is also the opton to add images here. just click on the on the image icon when posting your response.
Tue Jan 16 2018Reply from marcosanti2003@yahoo.es
The following items are necessary:
woc fine procedure.
Excel spreadsheet to find new gains.
laser power meter.
latex of 7 um.
laser protection glasses
fresh blood from patient with less than 04 hours.
the information and procedures I can send it to you by mail
