Mon Jun 11 2012
Hourly/daily rate limits via the CADD
Is there a minimum and maximum rate that the CADD and the CADD-Solis can handle?  I'm asking because I've been told by different sources that you shouldn't run flolan or remodulin in a CADD pump at a rate less than 2ml/hour (48 ml/day).  I'm trying to determine if this concern has to do with the pump programming limits or if running the rate less then 2 ml/hour will lead to line clogging?  Thanks for your help!
   RE: Infusion Pump Report Post
