Anyone replaced the hepa filter? If so, How?
Tue Feb 27 2018
Hepa Filter
Wed Feb 28 2018Reply from Alex Wright
Hello, I just added the operator's manual, and user guide to the documents of the CareFusion ReVel. I believe that the operator's manual may be able to help. If that does not help you, the transport guide is also now under documents for the equipment. If you scroll to the last page, there is a 24 hour help number for CareFusion you can call for assistance.
Documents can be found here
Hope that helps!
Tue Mar 20 2018Reply from Scott Geiger
The Pleated paper air inlet filter on the side of the Revel is MFG P/N 19826-001. It is easily removed without tools and is user replaceable. Internal filters can only be replaced by a MFG certified technician.
You can order from VyAire/CareFusion at 800-231-2466 and select the order entry team option.
