How do we know if our xli M1700A machine has the feature SAECG if it does how do we retrieve it if not can we send you our machine to install SAECG option
Fri Mar 02 2018
SAECG option
Mon Mar 05 2018Reply from Ray Brown, CBET
I think it will tell you that it has the SAECG installed when you turn it on. The problem with these old recorders is if the battery (3 6v batteries IIRC) runs down, the recorder will show a "6503" error, which is basically it has no software in it and you have to reload it. The SAECG was on a separate disk.
Mon Mar 05 2018Reply from Alex Wright
The companies listed below may be able to help:
Fri Jun 22 2018Reply from glevich
could you help me whith finding SAECG application disk? We have the saame problems whith battery. We find the base disk for standart ECG, but strogly needed SAECG option
