Tue Mar 06 2018
surgical light dark spot
We have surgical lights Medi Light model #011314 and one of them projects a dark spot in the middle of the illumination field. How to fix?
   RE: Surgical Light Report Post
Tue Mar 06 2018Reply from Valjak
Hi, is this light with halogen bulbs or...
Tue Mar 06 2018Reply from Milwood Animal Clinic
150 watt Tungsten Halogen
Tue Mar 06 2018Reply from Semrad
The universal answer:  IT DEPENDS
Has it always projected in this manner?
Is the light new to you or your office?
If this is a recent development, what has changed?  Bulb change, cleaning, accidental damage, relocation.
Did it start after Cleaning?  If yes, first look for anything that is out of aligmnent.  Look for dirty reflector or housing.  If the bulb was removed during the cleaning process go through removal/installation process.  Ask somone familiar with the process observe you.  Do they see you doing anything different?
Did it start after replacing a bulb?  If yes, was the correct bulb installed?  Don't roll your eyes, tt happens often.  Look for anything that is out of aligmnent, dirty reflector or housing.  Go through the removal/installation process again.  If you don't see anything obvious try another bulb.  Make certian it is the correct bulb!
Were adjustment made to the light other than movement to better see an area?  Has the reflector been moved in relation to the bulb?
Good luck!
Semrad
SEMTEK, llc
Then the problem could be in a wrong bulb type. For this op. lights are important position and shape of the filament because the reflector is designed for a specific bulb and reflection depends on geometry
Thanks all - we'll give all that a try. Have  a feeling it's an incorrect bulb
