Tue Mar 06 2018
NO VERTICAL MOVEMENT
Hi all, My Siremobil works fine, but the lifting column can't be moved. The EMERGENCY STOP button is not pressed. Has anyone had this problem? What can be done about it?
Wed Mar 07 2018Reply from Alex Wright
Alex Wright
The below companies may be able to helo:
SOMA
Denova Medical
RadRays
RSTI
Wed Mar 07 2018Reply from Tomelgy
The column drive motor is within the column.
Check if the EM switch & connector are connected.
Do you here any relays click when up or down buttons pressed?
Check you have supply voltage to column.
Tom
