Thu Mar 08 2018
Biomed Tech
I have a warmer that has a screen malfunction it will not light up when powered on what are some troubleshooting steps
   RE: Infant Incubators & Warmers Report Post
Tue Mar 13 2018Reply from AJ_Diaz
There are a few possibilities here:
1: Loss of 12V to Control PCA; Check to make sure the LED7 light is lit on the Control PCA. If the light is red, then the LCD module is receiving power.
2: LCD backlights are not connected to the Control PCA; Check the power cable between the Control PCA and Power PCA for correct pins; part# 6600-1567-700
3: Check the fuse F7 on the PCA Board
4: Check backlight connections at J4 and J8 on the Control PCA.
5: Replace the Control PCA; if backlights still do not work, replace LCD module.
Hope this help.
~A
Wed Apr 18 2018Reply from MarioLM
From my recent experience, replacing the CCFL Inverter #SE23337 and F3 fuse (don't know the actual value, put a 7 amp as trial) and this solved my problem. I have 2 other boards that have the same issue so I will order 2 more SE23337 chips from PartsSource (about $115.00 usd), better than a new board at $1500.00
Mon Feb 25 2019Reply from Phil802
Phil802
Thanks for the input on this forum. It helped me to resolve my power issue.
Fri Feb 10 2023Reply from MustafaM
Thanks very helpful info
