Mon Mar 12 2018
Philips BV 300 error codes
When I turn on the unit it display M010 Build-in self test fail. Also during expuser, sometimes apper an error M208.
Tue Mar 13 2018Reply from Alex Wright
Alex Wright
Hello, you can contact Philips directly for assistance!
You can also contact:
SOMA
Denova Medical
Tue Mar 13 2018Reply from chris?
Problem is the succo bd inside the c-arm is intermittent will have to replace it the sram battery on the bd is low causing the errors intermittent codes
Tue Mar 13 2018Reply from bfainsztein
I suspect that, any problem replacing the battery?
Wed Oct 27 2021Reply from juventino
Hello please any one can help me error 07006
Wed Nov 03 2021Reply from semmedical
Juventino: send me email at semmedical@gmail.com
Thu Nov 04 2021Reply from Ben C
Ben C
