The service LED indicator is on for the power adapter that is mounted underneath the defib. No error codes in the defib history and the unit is working fine. When the power cord is removed & re-attached, the service LED goes off. The service manual has no information on the power adapter and I can't find anything on the power adapter... Thanks for your help.
Tue Mar 13 2018
Lifepak 12 power adapter
Tue Mar 13 2018Reply from rsiefers
The service indicator can also be from the internal coin cell battery low and in need of replacement
But be wary, because if not careful all configurations will be lost and service will need to be called to reload
Tue Mar 13 2018Reply from ReNew14
if your servcie light is on the AC apdapter, it's usually the Main system pcb or the power outlet.
if main system board on the has failed , you can generally purchase a recertified one cheaper than having it repaired.
844-425-0987 and ask for Neil or Scott if you have any further questions.
I don't beleive i've ever seen the actual Unit causing the service light to come on the ac power adapter.
