how to fix a hidraulic cilinder
Tue Mar 13 2018
hidraulic cilinder
Fri Mar 16 2018Reply from Denova Medical
Is it leaking from the piston on the cylinder? Are you a technician? The cylinder can be removed and rebuilt. You should drain all the hydraulic fluid from the stretcher and fill with new. You probably will need to bleed the system after.
