Wed Mar 21 2018
Error message 4028 and 5011
could anyone know what these errors massage main 4028 and 5011 in the same time? Please help me.
Thu Mar 22 2018Reply from Alex Wright
Alex Wright
The below companies may be able to help:
SOMA
Denova Medical
RSTI
Thu Mar 22 2018Reply from Tomelgy
4028 is a Memoskop (Image acqusition part) message. Check D1 X10.27 signal.
5011 is a generator issue & probably caused your E4028. E5011 is main inverter board (D2) short circuit.
Try this, select manual kV (stop) set lowest kV (40) & press Fluoroscopy-on button, see if system works without error/s. If no error appears, slowly raise the kV & observe the monitor to see if there is any image & at what kV the 5011 error appears.
It could be an X-Ray tube or D2 kV/inverter board. I think most likely your X-Ray tube but you should check a few things first before ordering parts.
What model number Sirembil Compact do you have?
Tom
Fri Mar 23 2018Reply from semmedical
ERROR 4028
Possible trouble:    Host registered unexpected acq end signal of the Memoskop.
Possible help:    For failure investigation check the error log for additional error messages.
    Check faults on the Memoskop acquisition cable (D1.X10.27).
    Check Memoskop.
    Check connection cables to the Memoskop.
ERROR 5011:
Possible trouble:    Main inverter has short circuit.
Possible help:    Main inverter defective (board D2).
Sun Mar 25 2018Reply from ceshop
Error E4028 Memoskop unexpected acq end signal
Possible help: Check faults on the Memoskop acquisition cable (D1.X10.27).
Check Memoskop.
Error F5011 Gen. main inverter short circuit
