we have a different problem, the open door alarm won't stop even when the door are closed.
it's a sorvall RC6
any advice?
Tanks.
Thu Mar 22 2018
open door alarm
Thu Mar 22 2018Reply from Alex Wright
Hello, try contacting Ozark for assistance
Thu Mar 22 2018Reply from DFMK6
Thu Mar 22 2018Reply from sor
yes this is what i suspect, do you now where is sensor exactly, and there is one or more?
Check to make sure you are getting 5V locked and 0V open with your DMM from the left and right door lock solenoids.
The service manual is located under the documents tab if you need help locating them.
Fri Mar 23 2018Reply from sor
Wed Mar 28 2018Reply from david.rodriguez@bcw.edu
I've had similar issues with our RC-3BP Plus and the latch was broken. I think theres a bad run of latches
