ventilator failure
Thank you for your inquiry concerning Draeger. All product or service questions for Draeger devices can be directed to Draeger FREE of charge by dialing 1-800-4-draeger.
It will help Drager service technicians when calling them if you have the information found in the real time values section of the service access screen. Depending on your version of software, there is both an PSC error list and a ventilator failure code number listed.
Dear Brent
thanks for your support
we got following message after started up the machines ;Fabius
1.Ventilator FAILURE
2. Pressure sensor failure
3.Flow sensor failure
4.O2 not detected
shoul I replace Flow sonsor it may help as I know pressure sensor rarely damaged
I advised to make pressure sensor calibration
we appreciste advise us
best regards
Dr.Yahya
Unfortunately, you may have several issues with your machine. I would have to be there in person to start diagnosing all of the issues. It could be you have a defective processor assembly board with all of those problems. I would try contacting Drager for support. Good luck.
Dear all
I need Fabius GS service manual
still I have problem with my equipment
apprecaite support me
best regards
Hi dear !
please could you help me i have the same problem of my Fabuis GS it shows me that msg Ventilator failure, what did you do in case you have found the solution
thanks a lot
Check the power source and see all condensators because the problem is battery condensators too old then, the processor do not start correctly where is low DC Current Amp.
michael1234
Hi all
anybody knows who selling Dragger Fabius spare parts directly in Germany
best regards
