Wed Mar 28 2018
Procedure
Hi to all, i need replace the main board of this device and from Eppendorf says this procedure can do it only the oficial service because when you replace this PCB is necesary adjust the imbalance sensor. If in this case the information it's true: How can i do that procedure? Is posible to explain me? Thanks in advance...
   RE: Centrifuge Report Post
Wed Mar 28 2018Reply from Alex Wright
Alex Wright
Try contacting Ozark for assistance on this!
Thu Mar 29 2018Reply from Sahara Simba
For starters what model and serial number do you have?  Board replacements donot always require an imbalance calibration.
Check www.saharasimba.com
