Error 384 battery end of life
send me an email address to send the manual to. 384 normally means the Energy Storage Unit (ESU) the batteries need to be replaced. it is a timed event and to reset it you need to access the BVScope software on the system and select replace ESU. Philips being Philips does not give CSIP level 0 access to this function.
Help
what??
