Dear all,
I have a problem with my DuraDiagnost potter detector. This happen after a PM. the table detector is ok and can be calibrate. For wall stand there is a message appear when the system display " do not turn off detector IP adress configuration occur". then the message pass the system indicate both stauts are ok. but only table detector is working. only with table we can make exams. Need Help. waiting for your response. thnaks in advance
Fri Mar 30 2018
DuraDiagnost wall stand detector ip adress problem
Fri Mar 30 2018Reply from Alex Wright
Sat Apr 28 2018Reply from Rapidxray.biz
Trace your steps back and figure out what you played with....check connectors/cables/software......god only knows what may have happened but if no serious "electronic damage....like you messing up connections to the plate or slicing cables" happened it shouldbe easily recoverable.
