Polydoros RF ESU err 41264/80
RE: R/F Systems Report Post
Hello, Have you tried seeing if Technical Prospects to see if they are able to assist?
Based on your error code and APID your problem is definitely in the generator. In order to obtain more specific information, log into service with your service key and then go into the event log. The error code your have should appear as a blue link to the action plan if your service key is high enough. The action plan gives you specific information from the manufacturer as to possible causes and what to check to aid you in your diagnosis. Between that information and your schematics you should be able isolate your issue.
Feel free to contact us here at Technical Prospects for further assistance and guidance as you need.
John DiPasquale
www.technicalprospects.com
+1 (920) 757-6583
