Blank Screen
It sounds like you do not have continuous power to your Windows PC. There is a power supply on the left side which has connectors feeding power to the PC and it loses good connection. Usually I just have to remove the connector and clean the pins and then it works.
The power supply in on the right side near the operator drive position. It is about 3 inches wide and 8 inches long. If you send an email address I will send you a picture from the parts manual, page 46 item # 151
Art
On medwrench there is a parts manual for the Evolution. In that manual on Page #49 item # 18 will give you a general idea of where the power supply is on the Dart Model.
Art
The Relay HG2-AC100V-F AP6124F seems to be the culprit here. Where can I find this relay to buy? thanks
Pls, I still need help. I Changed the relay and still will not turn on. I then noticed the computer gets power. There is a power button on the front of it that if you push it comes on. I then took the computer out and changed the button battery but it still will not come on automatically as before. I now have the back of the unit open. What do I do to the get this working? thanks
The computer button either sets the computer to ON or OFF. It the switch is in the OFF mode it will not come on when you push the blue computer start button on the top panel. Push the small computer ON/OFF button "Once" and the computer will start. Then power down the system and try to power it on again from the Blue start button on the top.
Art
We're having this issue too. When I remove the panel on the right side, one of the HDSP A101 LED display is blinking red. Could this be our issue?
I have same your problem the blank monitor but i didn't find that relay HG2-AC100V-F AP6124F in spare parts manual
where did you find it please
