Hello, Does anyone know if there is grease points for the vertical column? I have one that is noisey at the top end of travel. If I run it up and down 5-6 times it quits for a few weeks. The manual doesn't mention any. IT only mentions if noisey to replace column. Thanks in advance.
Wed Apr 18 2018
Vertical column noisey
Wed Apr 18 2018Reply from BILL LEE
There are no grease points for that issue. I had the same issue with one of our units and ended up haveing to replace the collumn. It takes a little over seven hours. Because you have to disassemble the hole c arm.
Bill
