Wed Apr 25 2018
Philips c arm BV libra
kindly someone help as there is no console panel c arm stand ( mobile unit ) coming On . i have already changed the display panel and MIDAS board SHA1 but still have same issue no display.
Thu Apr 26 2018Reply from Alex Wright
Alex Wright
Hello, you can try contacting the following companies for assistance on this:
SOMA
RSTI
Philips
Sat Apr 28 2018Reply from Rapidxray.biz
Have you checked the supply cable? No brainer.....if the out put supplies are good then check data transmission runs. Pretty bland statement but does the monitor and onboard system boot correctly?
Thu Oct 01 2020Reply from mauri.ariel95
Alguno de ustedes cuentan con refacciones para ese modelo de arco BV Libra Philips, en caso proporcionare mi correo a continuacion.
Thu Oct 01 2020Reply from Ben C
Ben C
MedWrench es una comunidad informativa. No vendemos equipos ni piezas. Sin embargo, trabajamos como vínculo entre comprador y vendedor. Complete un FORMULARIO DE SOLICITUD y se lo pasaremos a una empresa para que se comunique con usted directamente.
