Overhead Tube System Locking up in random positions intermittently, reboot allows movement.
RE: Analog Radiography Report Post
Could be the brake in the drum or the D14 board that controls the brake. Is the SID changing on the readout okay? If it jumps around it may be the SID POT in the 3D.
When the lockup occurs, are there any error codes on the 7 segment display on the D14 or D50 (located in the table base). Also since this area is controlled by CAN communication have you verified the 5V supply and ensured that it is between 5.0 & 5.1 volts.
If you need additional support, please contact Technical Prospects for both parts and technical assistance.
John DiPasquale
www.technicalprospects.com
+1 (920) 757-6583
I did clean out the brake in the drum. I also noticed that the locking pin for the detents was worn on one edge. I cleaned them both and lightly lubricated them. It seemed as if the pins were sticking after hitting the release button for the traversal movement. It seemed to be actuating better after cleaning. since it is an intermittent problem I will wait to look into replacing the board till the issue is more consistent. Thank you for your help!
