Bed was raised to the highest position. Now it will not come down
Wed Apr 25 2018
repair
Thu Apr 26 2018Reply from Alex Wright
Alco Sales & Service Co. may be able to help you with this!
Fri Apr 27 2018Reply from LuisCholo
enter the calibration menu of the sensors, if by that means everything works, then your problem is not electronic. Check the wiring of the guardrails that are normally split in the latch lock area.
I hope this helps you
