Tue May 01 2018
Hemoglobin analyzer product
Can someone suggest me the best hand held hemoglobin analyzer ?
Tue May 01 2018Reply from Nirosha K
I would personally recommend EKF Diagnostics' DiaSpect Tm as the best hematological analyser machine. I have bought this machine recently to test my hemoglobin level at home and collect a blood sample from any angle without forming air bubbles.
DiaSpect Tm delivers laboratory quality results in just about one second of the microcuvette being placed into the analyzer. I really loved this equipment as it is palm-sized and hence easy to transport and use in any environment.
The best qualities of DiaSpect Tm are:
  • It is FDA Approved equipment
  • It provides the fastest results
  • It contains rechargeable internal battery, which provides up to 40 days / 10,000 tests continuous use.
  • It provides the flexibility of not needing a power source for weeks at a time
  • The microcuvettes have a shelf life of up to two and a half years and can be used until the expiration date, even after opening the bag. This makes them ideal for settings with low prevalence of anemic patients.
  • The microcuvettes are unaffected by humidity or temperature and are therefore particularly suited for use in hot and humid climates.
You do the measurements in simple 3 steps:
DiaSpect Tm hemoglobin analyzer specifications:
  • Easy to use
  • Practical and portable
  • Accurate and reliable
  • Reagent-free microcuvettes
For more info: You can check: https://www.asianhhm.com/hand-held-hemoglobin-analyzer
