Wed May 02 2018
Power problem
Hi, I have an Optima XR200AMX. The Mantis power supply has an LED indicating it is getting AC power, but the LED for the output is not lit. Do I need a new Mantis power supply? I moved the jumper for the heartbeat and no change. Any other suggestions?
Thu May 03 2018Reply from Alex Wright
Alex Wright
Hello, you can try contacting GE Healthcare directly for assistance.
Sun May 06 2018Reply from AlfredBM
Hi, try disconnecting the outputs cables (J2 & J3) and check the LED, maybe you have a shortcircuit in another board. If you disconnect the cables and stay off the output LED, you have to change the power supply, try opening the power supply and check it, maybe the failure is something ease, like an internal fuse..
Mon May 07 2018Reply from TGM0
Thanks for the advice Alfred. I will give that a try.
Mon Mar 22 2021Reply from ABDOH
Please give me fedback after you replace maintis power supply
Is system worked or need other spare parts
