Fri May 11 2018
Errors on Siemens Powermobil C-Arm
I have a Siemens Powermobil that has errors 2025 and 5604 on bootup. The errors can be cleared and the unit works normally. I have checked all system voltages and x-ray outputs. They are all normal. The time and date are correct on the workstation. Just can't get these errors to not pop up on startup. Any help would be greatly appreciated.
Mon May 14 2018Reply from Alex Wright
Alex Wright
Try contacting SOMA or RSTI about this issue. They may be able to assist you on this.
Wed Nov 10 2021Reply from Santiago Frick
I have the same errors in the bootup. Do you solve it?
