Tue May 15 2018
GE HISPEED CT/I
Hi friends, need service manual book for GE HiSpeed CT/i  Getting error: The SBC is not responding... after putting song command.. {ctuser@ct01} [1] st Remote licence file is not present Determining the state of SBC....ping SBC....ping SBC....ping SBC... and continue same... Thank you
   RE: CT Scanner Report Post
Tue May 15 2018Reply from Alex Wright
Alex Wright
Hello, Try contacting GE Healthcare directly or call their technical support number at: 1-800-437-1171
Wed May 16 2018Reply from semmedical
Wed May 16 2018Reply from Alex Wright
Alex Wright
Sun May 20 2018Reply from lee0857
You dont need a remote license. The SBC is in the base of the table. Nothing will come up if it doesnt work. Typically it is the supply for the SBC.
Tue May 22 2018Reply from Ctdude
The SBC bd. has two batteries on it. One is a NVRAM and the other is a 4 prong square made by Rayovac. The SBC bd is located in the console on the right side behind a panel with three thumb screws. From a unix shell you can use the rsh or cu commands to try to establish comms with the SBC. If the NVRAM is replace it will need to be rebuilt witth all the correct boot parameters. The SBC is not located in the table. The CT/i system has three controllers STC, ETC and OBCR......STC is located on the stantionary frame of the Gantry......ETC located in the Table base.......OBCR located on the rotate frame of the Gantry. Back to the SBC not responding...check cables between Octane comuter, bulkhead and SBC.
Sat Aug 01 2020Reply from Hernando Florez Anaya
Hola me podrían ayudar a conseguir el manual del tomografo GE CT/I
Mon Aug 03 2020Reply from VEMPA
Hernando te puedo ayudar con eso, enviame un email a guerydiaz@hotmail.com
Wed Aug 19 2020Reply from Ben C
Ben C
MedWrench está disponible para ayudar a las personas con preguntas específicas y solución de problemas. ¿Podría ser más específico con el problema que tiene con su equipo? Esto también ayudará a otros miembros de la comunidad que enfrentan desafíos similares.
