Bought a medfusion 3500 for experimental purposes, it has a memory of libraries we don't need, how do we reset the pump to default
Tue May 29 2018
how to reset to default
Thu May 31 2018Reply from Jennifer.Light
It's called doing a "Pharmguard transfer". To do the transfer there's apparently a program you need and an IR cable you need to transfer the data to a computer. You can also change to settings to basically keep the newest update and to dump the oldest (so that it will never ask you to do a Pharmguard transfer again).
Thu May 31 2018Reply from biomed6165
Power the unit on, select any profile, select "more" until you see the screen with 2 options: 1-Profile Settings & 2-Biomed. Select 1-Profile Settings. Enter 2580. Select restore default config.
