Tue May 29 2018
Error code 200.6120
I had a pump module that came up with this error, plus a software fault in regards to Object 13-104-1057 at the same time. Is there a common problem that would cause this? Thanks! Craig
   RE: Infusion Pump Report Post
Tue May 29 2018Reply from Alex Wright
Alex Wright
Some of the errors and common issues are explained in this manual: https://www.medwrench.com/documents/equipment/7209/carefusion-alaris-8100
