Don't suppose anyone could send me a copy of the backup data disk
Howdy,
I am fairly sure a Preset Data disk from another SSD-3500 is not going to help because the options are serialized. You might be able to get out of the Auto Test loop by doing a complete system reset. However, I think the BIOS settings need to be reset manually because the CPU battery went flat before it was replaced. Then you will need to get a Hard Disk Drive image file for your system from Aloka or one of their distributors. AUE may be able to help you with that, depending on where the system is located.
I am afraid it is too late now, but you should have been able to backup the HDD data to either a floppy disk or to a MO disk. Which one you need depends on the size of the Preset Data file, which is one file and can exceed the 1.44 MB capacity of the floppy. The media needs to be DOS formatted before use, and if an external MO drive is used it needs to use the IDE interface. Later versions (V7 and up) can use an external USB hard drive to make the Preset Backup. If you have an Aloka system, make sure you have a Backup disk today! In fact, make sure you have 2 copies.
Jim Carr
AUS
USA office: +1 918-628-2831
1st, thank u for taking the time to help me, know it's sincerely appreciated.
As for resetting the Bios, I may have missed it but I have scoured the service manual and I didn't see any info on it. There is a jumper pin beside the snaphat battery, I'd guess you turn it on but I hate guessing
