Cant get the monitor to start up despite changing the motherboard, sram card, checking powersource and connections. There appears to be a communication problem between the two parts.. any ideas?
Thu May 31 2018
troubleshooting starting
Fri Jun 01 2018Reply from oldxrayguy
Fri Jun 08 2018Reply from Alex Wright
Best regards,
The MedWrench Team
