Foot Control
RE: Power Report Post
As you mentioned that the foot control cable was pulled out and that another known good foot control didin't work, I would disconnect power and start by removing and checking the foot control inlet harness (part 015-3463-00) which goes from the main PC board (Connector J8) to the foot control port. Check for physical damage (especially the pins for any that are missing or bent) and ohm out all the wires to make sure you have good conductivity. While your at the main PC board, remove and check fuse F4 to make sure theres good conductivity. Hope this helps. - Cipher
Update: Sorry for the late update, it's been crazy around here. I ended up changing the foot control inlet harness and the foot control itself. The problem has been resolved. Thank you for your input.
