I have problem with FUJI CR-IR 391CL. When you start program - it starts and connect to SQL server, but can't load Patientportal.exe and windows stops it. I try to clear the database and renew it, but didn't load it again. I uninstall the CR-IR 391CL, but when I try to install it - I have this error:
https://drive.google.com/open?id=1Ugr4QYNmi99WXVVImLySx0iesrpbTde5
P.S. Someone to know what to do ?
Tue Jun 05 2018
FCR CR-IR 391 CL problem
Wed Jun 06 2018Reply from S. Popov
Finaly I understand for what is this windows error and fix it. But now when Install finish, it give me this error:
"Database creation failed.CreateMasterData.bat SpotCode=2"
and rolling back the install files and settings.
Thu Jun 07 2018Reply from Alex Wright
Hello, can you explain to us what this error was and how your were able to fix it?
Fri Jun 08 2018Reply from S. Popov
I had to open Task Scheduler and delete two FCR tasks and then install continiue...
And t he problem with Database was fixed too. Just I had to reinstall and SQL programs and DELETE old sql files - then CR-IR 391CL installs and create new databases...
Mon Jul 23 2018Reply from equipments.doctor
Mon May 08 2023Reply from Khatabpx
