Thu Jun 07 2018
Lateral Tilt
Hi I have a stuck lateral tilted fully on the right side. Any assistance would be appreciated. It is a manual table.
Thu Jun 07 2018Reply from TYCapitalism
I had a similar issue. Did you try holding down the emergency override button until it chirped then try the butttons again?
Thu Jun 07 2018Reply from barkyboy
Check the underside of the Table. There is a pin in the shaft connects the pinion gear to the mechanism. It is probably broken. I have had to replace it on several occasions.
Barkyboy
Thu Jun 07 2018Reply from Kara Crissman
Dear Oilcan,
We came across your post about the AMSCO 2080 Table. We have a dedicated Service Support team who can help. Please provide us with your preferred method of contact or call 1-800-333-8828 for assistance.
Sincerely,
Kara Crissman
STERIS Corporation
