I need help. How do I get my machine to turn on with just the power button. I currently have the units back open, so I can reach the computer on button. So, I push the blue power button then push the computer on button. It works normally by just pushing the blue power button and everything comes on. How do I restore to that?
Thanks pls see what I am describing here. thanks for your help
https://drive.google.com/open?id=17EoKnL7tp6xiI1gDfNdQIOjVgZrZuy5Q
Mon Jun 18 2018
Computer not turning on with the blue power button
Mon Jun 18 2018Reply from Arthur
Hi,
Check the BIOS and insure it is set to "power on" after power loss. Also after you push the blue button and it does not come on, push the computer power button on once. Then allow the system to boot up and shut it down from the application. Then try the blue button again for turn on. I think the computer power button is not a momentary switch but an on/off switch and it must be left in the on position
Art
Tue Jun 19 2018Reply from drruc
Hello Arthur
i have checked the BIOS and everything looks fine. The on button is not movable to on or off. Just a push button.
pls how can I reach you to further assist?
Thanks
Daniel
Tue Jun 19 2018Reply from Arthur
