Machine was giving internal error, installed SW(software Disk.1 OS, Disk.2 OS 09A, Application, Drivers), while installing SW,Disk1.Os installed successfully bust when it ask for Disk.2 Operating system, then inserted Disk.2 OS but it says "cannot found Batch file label specification: Installing ..". and then it proceeds till asking for application and then drivers, but after drivers again machine ask for Disk.2 OS and then same message "cannot found Batch file label specification: Installing .." then system stop further. some one told that this is due to SPB (video graphic card is faulty)....looking some experts guidelines.
Fri Jul 13 2018
Philips - HD11 XE SW software nerror
Fri Jul 13 2018Reply from Kennedy Krieg
Hello! Please try contacting the following companies to help you with your question:
Kennedy Krieg
Mon Jul 16 2018Reply from Alex Wright
Best regards,
The MedWrench Team
