Fri Jul 13 2018
Bio-Rad DiaCent-CW cell washer: Tilt vibration alarm impossible to fix
Hello, on our Bio-Rad DiaCent-CW cell washer: I get a "Tilt vibration detected" alarm, and could not fix or adjust it. I tried to remove the vibration detector, to perform the vibration detector adjustment (potentiometer underneath the unit) and the tilt sensor adjustment (on-screen procedure), but the alarm remains once in a while. Bio-rad suggests I replace the main pcb, What do you think? Thank you for your help.
   RE: Centrifuge Report Post
Fri Jul 13 2018Reply from Alex Wright
Alex Wright
IF it is B007 it means "Data Set does not match SOP Class" and is classified as a warning.
