Can anybody help? I have Regius 110 working with Image pilot. Image pilot has an CR reader fixed on 192.168.20.170, and my Regius IP is 192.168.1.3. Is there any option for changing either regius IP or assigning another IP for reader in Image pilot?
Best regards,
B
Thu Jul 19 2018
Change an IP address
Fri Jul 20 2018Reply from Kennedy Krieg
Hello! Please contact RSTI to help you with your question.
Kennedy Krieg
Fri Jul 20 2018Reply from evana007
you may change the IP address by using Hotspot Shield VPN. it is an extension which is used in the Google Chrome browser. or you may check it from Gmail Customer Support for a proper solution.
Fri Jul 27 2018Reply from kecman
Thu Nov 01 2018Reply from Marcelo Colombo
É muito simples, basta você abrir as propriedades da placa de rede do Regius e adicionar uma faixa de ip na placa: 192.168.20.1 no gateway aí vai comunicar nas faixas diferentes.
Sun Dec 16 2018Reply from guiness.one
