Hello I have a 3023 lab sterilizer. This machine has 2 control boards as it has been referb by steris and now is a renaissance. I keep loosing time and date there is a 2k battery and 8k someone mixed these up and now I'm not sure what control board receives which battery and there are jumpers to move on each control board for this. Steris wants $500 for the manual as the lab indicates they do not have the manual and i can not locate one online. Can anyone help me?
Thu Jul 26 2018
life science
Thu Jul 26 2018Reply from Kennedy Krieg
Wed Aug 01 2018Reply from Cipher
Locate Jumper JP-4 on the boards and ensure you are viewing the JP-4 writing right-side-up. If U1 and U2 is above JP-4 you are viewing the board correctly. If jumper JP-4 is across pins 2 & 3 (center and far right pin), then that board is for the 2k battery. If the jumper is across pins 1 &2 (center and far left pin), then that is for the 8k battery. Hope this helps. - Cipher
