Sun Jul 29 2018
error code
Just replaced the power supply, now getting wrench light and 5 min. light flashing. Any help greatly appreciated!
   RE: Centrifuge Report Post
Wed Aug 01 2018Reply from Cipher
Cipher
This particular flashing light combination indicates that Latch is not locked. First, confirm that the cover is fully seated in closed position. Next I would check you cable harness for loose connections. Your Latch could also be defective. Hope this helps. - Cipher
