I am getting an error code in using the machine AGFA CR 35X,and facing a lot of difficulties...
Plz Help...
Wed Aug 01 2018
ERROR CODE 20506
Wed Aug 01 2018Reply from AgfaDoog
20506 E_SCN_LASER_SHUTDOWN Meaning : Laser power after the warming-up phase is still below or equal las_pow_shtdn. No operation possible. Reason : - Old laser with too low power. - Laser beam not visible by PIN diodes. - Cable to PIN diode board disconnected or defective. - Polygon gets no power or sweep signal. - PIN diode board defective. - pd_factor not correct. - Bad (dusty) optics. Cure : - Check cable and connectors to PIN diode board. - Check if nothing hides the laser beam. - Check the polygon power. - If laser is bad, replace laser.
"...Hello, IT... Have you tried forcing an unexpected reboot?..."
The IT Crowd
Check my LinkedIn profile for more info: https://www.linkedin.com/in/aacch/?locale=en_US
Available to move, looking for a job overseas full time :)
Wed Aug 01 2018Reply from Kennedy Krieg
Hello, please refer to the service manual located here.
Kennedy Krieg
