Is there a Aortic Pressure Module for the IntelliVue X3 that supports an aortic Anolag Output?
Thu Aug 23 2018
Thu Aug 23 2018Reply from Alex Wright
Hello, For this queuestion I suggest checking with the following companies:
Thu Aug 23 2018Reply from Ray Brown, CBET
Not directly with the X3, no. (We don't have any X3 monitors here yet, but I got the service manual for it.) What you can do, however, is when the X3 is docked into the Intellivue Dock, you can access the analog port that can give you either ECG or PRESS outputs, to run your IABP. :-) The same cables that worked on the old Merlins should work with these new docking stations.
