Fri Aug 24 2018
how to make saline solution
My department just assumed cleaning of GE Tee probes. It was brought to my attention leak testing was not being performed which I indend to do. We dont do many TEE's here at our hospital so they wont buy another leak tester. The manual calls for a saline solution of 50g NaCl/1000g H20. Can anyone please help me on how to make this solution as the tech support doesn't seem to know?
   RE: Ultrasound Transducer Report Post
Fri Aug 24 2018Reply from Alex Wright
Alex Wright
Hello, which GE Tee prob model is this?
Fri Aug 24 2018Reply from NURSEJOE
Ge Tee probe 6T and 6VT-D
Mon Aug 27 2018Reply from Alex Wright
Alex Wright
Thank you for clarifying,
In this case, I recommend contacting some of the below companies to see if they can help:
AUE
Conquest Imaging
Pacific Medical
Summit Imaging
Trisonics
Mon Aug 27 2018Reply from Jim Carr
Jim Carr
First of all, thank you for assuming that resposibility and helping to assure the safety of your patients! TE probes shoudl be tested before each use to avoid cross-contamination, chemical poisoning, and the unlikely (but possible) risk of electric shock.
That ratio is about 3 tablespoons of salt per quart of water. However, you should be able to use tap water. I have tested probes all over the USA and some other countries including France, Germany, Mexico and the UK. I have yet to find tap water that was not conductive. Ultrasound leakage testers typically have a test of the conductivity of the bath that is done just before the leakage test, which will tell you if it is conductive. Also, you may be able to test them in the disinfecting solution because those are very conductive. Remove the TE probe if it fails, though. No reason to cause even more damage to the articulation cables and the other expensive components inside the probe.
Jim Carr
AUS
USA office: +1 918-628-2831
