Mon Sep 03 2018
Trendelenburg and down movement
When I press the down pedal or button, the bed at first goes down, but then it just does the trendelenburg even if I'm not pressing any movement buttons. When it finishes the movement, the bed locks itself for like a minute, after the minute you can now move it again.
   RE: Bed Report Post
Tue Sep 04 2018Reply from Ray Brown, CBET
The bed should not be moving if none of the controls are not activated. Sounds like a problem with the logic PCB. You might want to see if any of the processor chips are loose, or just exercise them (remove and reinsert them a couple of times). Otherwise, a new logic PCB.
