Tue Oct 02 2018
ERBE - APC 2 - Performance Check Procedure
Hi, Does anyone have a procedure to perform a performance check on this unit? Thank you for any information
Thu Oct 11 2018Reply from robotech
I was looking for the same thing today.  Contacted Erbe who said they do not have PDF copies of the manuals and such.  I have the hard copies.  All it states is that a safety check should be performed after every repair and every 12 months at a minimum.  There is then a bullet list of things to do (with no details), ie visual inspection, performance test, pressure line test.  I can send you the scan if you do not have the hard copies if it suits you.
Thu Oct 11 2018Reply from bcalvert
Hi robo,
Yes - hard copies would be great! Please send them to:
bcalvert@chemtronics.com.au
Thu Jun 11 2020Reply from sh
@bcalvert
can I have the scanne copy too??
Tue Jun 16 2020Reply from slward2004
Can I have a copy as well?
sheriward@CATHOLICHEALTH.NET
Mon Nov 01 2021Reply from Hambiomed
can anyone provide me with a copy of this?
hramirez@montefiore.org
thank you!
Wed Mar 23 2022Reply from Al G
For those that got a copy of the performance inspection test, please send a copy to: agaviola@northwell.edu   thanks in advance.
Tue May 09 2023Reply from bigcat488
For those that got a copy of the performance inspection test, please send a copy to: stephen.k.hyle@med.ge.com   thanks in advance.
Fri Jun 16 2023Reply from JScriv
I would also greatly appreciate a copy of the performance inspection test procedure, thanks.
jesse.scrivanich@ge.com
Wed Jul 05 2023Reply from Edwin Gonzalez
Sun Jul 09 2023Reply from MikeAMend
TSF for APC2, send for all  you
