error 328
Z-axis (up/down) movement failure.
Turn the power off, and then see if you can move it up and down smoothly.
1: Obstruction in up down movement.
2: Problem with the linear bearing and/or shaft. Clean and lubricate it, and then move it up and down (with power off).
3: Problem with cable and or motor.
4: Problem with optical detector for motion.
Ross
Thank you
Where can I get step-by-step instructions On how to clean and lubricate the linear bearing and\or shaft
First, with power off, push the Z stage down all the way. Clean the upper part of the shaft with paper towels or gauze, and then with PT or gauze moisten with alchol. Then lift the Z stage all the way up, and then clean the bottom part of the shaft as before. Note that there are grooves in the shaft (there are either 3 or 4, I can't recall) - clean these carefully - perhaps cotton-tipped applicators would be best to get them clean.
Then use a good quality grease - Superlube, or a silicone grease to wipe onto the shaft, alternately moving the Z stage up or down. Force some similar oil into the grooves (Superlube oil, if you used that Superlube grease, or silicone oil if you used silicone grease). Then move the Z stage up and down repeatedly, to see if it begins to feel smooth.
Then try it with power on, to see if it can move without binding and generating errors.
Try this repeatedly if you still have problems. If that doesn't solve it, there may be an additional, more involved procedure.
Hi Ross
Did the cleaning and greasing procedures as described.
The Z shaft moves up and done but it is very stil - I do not know if this degree of stiffness is normal.
when I turn the machine on I hear a faint click but no motor is running.
Why are my next steps?
Do you get an error? If so, is it still 328? Does the arm move in any direction? Have you tried to run a program?
Ross
I get the same error on turning the machine on. When the machine is off I can move the arm quite easily in the X and y axes. The z axis is very stiff despite the cleaning.
I cannot run a program.
Thank you
With Regards,
Capsimpex sarl
http://capsimpexsarl.webnode.fr
Thank you Ross
- the linear bearing had only two holes in the center of the bearing. ( I exposed them but did not remove the entire bearing from the clamp) I filled those holes but they made no difference in the mobility of the z axis (which as I said before is stiff but not completely seized up).
what is the next step?
Thank you Ross
- the linear bearing had only two holes in the center of the bearing, opposite to each other. ( I exposed them but did not remove the entire bearing from the clamp) I filled those holes but they made no difference in the mobility of the z axis (which as I said before is stiff but not completely seized up).
